Enamel paint removal
Postby Shally » Fri Feb 12, 2016 3:11 pm
Hello,
Several years ago I built a Qantas B747-400 in the previous livery. I now wish to repaint it in the current livery. Does anybody have any tips as to how I can remove the old enamel paint?
Thanks.
Shally
Re: Enamel paint removal
Postby bg_451 » Fri Feb 12, 2016 4:39 pm
Try a degreaser spray from supercheep or equivalent auto parts store. As the enamel is oil based, the degreaser breaks it down and you should be able to strip the model.
If there are acrylics underneath, it won't strip them though. You could try oven cleaner spray for that.
Hope that helps,
John
There's someone in my head but it's not me
bg_451
Postby harvs73 » Sun Feb 14, 2016 8:14 pm
I found that over cleaner used to remove it easily with a bit of scrubbing and then washed off.
Site Admin
Postby Shally » Mon Feb 15, 2016 7:59 pm
Thanks for the replies.
Shally
Postby CJP » Wed Oct 18, 2017 11:23 am
Been searching how to remove paint from an old Hasegawa A4 so good to pick up on this tip - tried it with Easy Off Oven Cleaner & left in a Woolies bag overnight - 90% came off with soapy water & tooth brush first go & I'm sure I will get the rest with a repeat treatment
CJP
CJP
Postby mogin » Mon Jan 22, 2018 12:30 pm
Dettol
On Bench: 1/72 Revell B17. 1/48 Academmy F-22. Revell 1/32 Hawk. Hobby Boss A10 N/A. Academy 1/48 F-22. Tamiya 1/48 F-15J. The list goes on......
mogin
Postby sapperastro » Mon Jun 24, 2019 11:27 pm
I have removed MOST paints easily by submersing the model in metho and giving it an initial scrub with a toothbrush. Leave it submersed o/n. Next day, give it a scrubbing with the toothbrush and the paints usually come right off.
sapperastro
