LF - 1/72 F-4 Phantom decals non-camo if poss
Member's Area Marketplace
Place to buy and sell everything modelling
Postby gilltech » Sun Aug 25, 2019 7:10 pm
Hi there,
Hoping that someone might have some surplus 1/72 F-4 Phantom decals - wanting non-camo eg. USN, RAF or ??? - they would like to on-sell? I'm a bit over the SEA / Vietnam era camo scene by now.....
TIA
John
gilltech
Re: LF - 1/72 F-4 Phantom decals non-camo if poss
Postby qfa_tsv » Mon Aug 26, 2019 11:33 am
any particular model of Phantom?
Postby gilltech » Tue Aug 27, 2019 5:55 pm
It's a F-4G Wild Weasel kit but can also be built as an E or F.
It's an older Italeri kit and the decals in it are starting to yellow.
Edit:
(My model is not suitable for RAF, as apparently the RAF ones were Ks, and a different shape).
gilltech
Postby mozit » Wed Aug 28, 2019 10:52 am
You could tape the decals onto a board and put them out in the sun and they should come good again. Depending on how bad they are and how strong the sun is, a day or 2 should do it. Maybe wait for spring/summer .......
mozit
Postby gilltech » Wed Aug 28, 2019 6:12 pm
Well that sounds like a good trick, a new one on me, well worth a try - so what happens, the UV bleaches the film?
Thanks for the tip, I'll see how I go!
gilltech
Postby mozit » Wed Aug 28, 2019 6:36 pm
I knew I shoulda taken some before and after shots!
All I can offer is the attached comparison of a pair of very old KP La-5 decals - one bleached a couple of years ago, one not. Could have bleached it more ...
La-5 decals.jpg (233.99 KiB) Viewed 1878 times
mozit
Postby DDGboy » Thu Aug 29, 2019 10:34 am
Can 100% guarantee this works, do it myself ALL the time. Ol' Sol even has a crack at Japanese ivory whites (older Hasegawa, Tamiya etc), helps but only the direct application of fire can fully fix them...
I usually sit mine in a sun-drenched window (which is pretty much all year round in heave...sorry, Tweed!) for a day or so, just be careful as they will bow with the heat (will flatten as they cool afterwards, I often stick mine at the bottom of a HUGE book for a few days) and if they touch the glass and there is any moisture about they can stick. On less-windy days I'll put them outside weighted down with a pebble or something, but 9 times out of 10 I'm doing laps of the yard later trying to find them...
I often coat them with Microscale Liquid Decal Film once de-yellowed, no point doing all that just to have them explode on contact with water!
My error spotting skills BEFORE I hit send/submit - 0.00010%
My error spotting skills AFTER I hit send/submit - 110%
DDGboy
Postby gilltech » Thu Aug 29, 2019 7:37 pm
Thanks so much for the tips guys! A big help. Bring on the sunshine...
I'll get some Liquid Decal Film too, I have had a couple of decal sheets that looked perfectly fine only to explode in the water - the decal and the backing paper expanding at different rates it would appear.
I mostly only buy pre-owned kits for me and my boys so this advice will help us a lot thankyou.
gilltech
Postby RayS » Fri Aug 30, 2019 8:22 am
Just a couple of notes on sun bleaching decals.
I put them into a resealable clear plastic bag and them tape the to a north facing window. It can take up to 3-4 weeks for the sun to work its magic. So don't expect it to happen in day or 2 with older decals.
If the bleaching fails, I might have some spare non SEA decals for an F-4E, I will take a look in the stash.
Postby hrtpaul » Sat Aug 31, 2019 1:42 pm
I've probably got heaps but I'm not home for another couple of weeks yet.
