Looking for a Contrail 1/72 Blackburn Kangaroo
Member's Area Marketplace
Place to buy and sell everything modelling
Postby Peter Roberts » Tue Jun 18, 2019 1:54 pm
Hi All
I know, a long shot, but if you have a 1/72 scale Contrail Blackburn Kangaroo in the stash and are happy to remove it, I am happy to take it off your hands.
Please PM me if that is you,
Thank you
PR
Peter Roberts
Re: Looking for a Contrail 1/72 Blackburn Kangaroo
Postby Peter Roberts » Mon Jul 08, 2019 11:59 am
Or anyone seen one around the traps?
PR
Peter Roberts
Postby lawqbarr » Wed Jul 10, 2019 7:05 am
Hi Pete
May I suggest you have a serious look at scratching building this one
Contrail kits are not terrible, but you'd probably end up with e more accurate and stronger model if you scratch build the whole thing.
A slab sided airframe like the Kangaroo's is not hard to make from sheet polystyrene and the wings and tail assembly can be done easily using the "Woodman" method
There's your basic structure !! - if you are using a Contrail kit you have to do all your own detail work anyway
If you want some references I can help - PM me - you have my direct email
regards
David
(you sold me that detail set for the 1/32 Mirage )
lawqbarr
Postby Peter Roberts » Wed Jul 10, 2019 7:37 am
Hi David, thanks, yes, looks like that is the way I'll have to go, but will likely do 1/48th if so. I was looking to hopefully cut down time a bit with some preformed parts. Oh well. Thank you for the offer the re: references.
PR
Peter Roberts
Postby sfuryb5 » Mon Sep 16, 2019 10:49 pm
pm sent re blackburn Kangaroo
sfuryb5
