Tiffie - Finished & On Display.
Postby RAAFBrat » Sat Sep 15, 2018 8:31 pm
And on to the next project. After the battle to finish the Seafire & Lancer, plus all the dramas away from modelling, I needed a quick simple build as therapy & this very old Monogram 1/48 Typhoon fit the bill. Now considering that the kit only cost me around $5.00, the PE was a tad expensive at $19.00 & then I discovered that it was missing a main wheel - which were pretty crappy anyway. So another $10.00 later for a couple of resin wheels..................... :roll: This aftermarket stuff can get outta hand :D . So when I came across a set of "Sharkmouth" decals for $14.00 I thought about it, but......................................The kit decals are stamped "1990", look ok & I usually don't have trouble with Monogram decals so I'll try them first. This is as far as I've got so far.
Tiffie 001.JPG (233.88 KiB) Viewed 1589 times
Tiffie 002.JPG (235.91 KiB) Viewed 1589 times
Tiffie 003.JPG (245.84 KiB) Viewed 1589 times
Tiffie 004.JPG (230.45 KiB) Viewed 1589 times
Tiffie 005.JPG (90.8 KiB) Viewed 1589 times
Re: Tiffie.
Postby noelbarnes » Mon Sep 17, 2018 3:30 pm
I built this kit many years ago and loved it. I was surprised at how well it went together. I didn't have all the bits and bobs you have added. I look forward to seeing how it turns out.
noelbarnes
Re: Tiffie.
Postby RAAFBrat » Mon Sep 17, 2018 4:40 pm
Thanks Noel. Yes, for a 1990 issue of a '69 mold - it's fitting together brilliantly. Far better than my last 2 Airfix kits. But I have always liked the Monograms. :)
Re: Tiffie.
Postby RAAFBrat » Mon Sep 17, 2018 8:49 pm
Update on Tiffie. As I hoped, this is proving a quick build as I got her closed up today, with wings & tail-planes on also. Just about ready for paint.
Tiffie 001.JPG (93.36 KiB) Viewed 1545 times
Tiffie 002.JPG (86.83 KiB) Viewed 1545 times
Tiffie 003.JPG (231 KiB) Viewed 1545 times
Tiffie 004.JPG (112.83 KiB) Viewed 1545 times
Tiffie 005.JPG (205.54 KiB) Viewed 1545 times
Tiffie 006.JPG (207.97 KiB) Viewed 1545 times
Tiffie 007.JPG (135.38 KiB) Viewed 1545 times
Tiffie 008.JPG (190.98 KiB) Viewed 1545 times
Re: Tiffie.
Postby RAAFBrat » Thu Sep 27, 2018 6:26 pm
As I hoped, the Tiffie was a quick build. A good thing as we head off interstate tomorrow for a couple of weeks.
If I might present the little-known stable-mate of & successor to Hawker Hurricane V7476, sent like it's little brother to Australia as an evaluation machine when Hawker's was looking for more sales & reacted to RAAF's purchase of Spitfire Vc's & VIII's. Sadly, nothing came of it, especially as the RAAF's role turned more to ground-attack as the war progressed.
Kit is the ancient Monogram 1/48 with Eduard cockpit PE & High-Planes resin wheels. Paint is Tamiya acrylics, the Silver is British Paints "Paint & Prime" Metallic Silver spray-can, with Tamiya TS-13 Gloss Lacquer spray-can over that. I came to the Tamiya after trying both British Paints & Dulux Gloss sprays on test parts only to have it "grey" the paint down. Decals from the spares box.
For a 1990 release of a 1969 model, it went together really easily. A couple of fit issues if you look closely but not bad for such an old kit.
Tiffie 021.JPG (103.72 KiB) Viewed 1467 times
Tiffie 023.JPG (228.05 KiB) Viewed 1467 times
Tiffie 025.JPG (92.07 KiB) Viewed 1467 times
Tiffie 027.JPG (102.97 KiB) Viewed 1467 times
Tiffie 029.JPG (65.57 KiB) Viewed 1467 times
Tiffie 030.JPG (110.11 KiB) Viewed 1467 times
Tiffie 036.JPG (233.33 KiB) Viewed 1467 times
Tiffie 037.JPG (212.56 KiB) Viewed 1467 times
Tiffie 038.JPG (215.79 KiB) Viewed 1467 times
Re: Tiffie - Finished & On Display.
Postby qfa_tsv » Thu Sep 27, 2018 7:16 pm
I wasn't quite expecting that, but very nice job
Postby RAAFBrat » Thu Sep 27, 2018 9:54 pm
Thanks Graeme. I felt like something different, gave it a coat of silver to see what it looked like, and.......................:D
Postby RayS » Fri Sep 28, 2018 9:13 am
Very nice Steve, looks 'right' in that scheme
Postby DesTROYer » Fri Sep 28, 2018 12:55 pm
Great job. I really like it.
Postby RAAFBrat » Sat Sep 29, 2018 8:16 pm
Thanks guys. It was a fun build. Maybe I should do my P-47 in camouflage as payback? :D
