1/32 Aerotech Piaggio Pc7 Finished (with glamour shots)
Postby ericg » Thu Aug 30, 2018 2:32 pm
So after finishing the Ansaldo A.1 I thought I would get stuck into something simple and quick, whilst still keeping things a bit obscure. I chose the Aerotech Piaggio PC.7, as I have built a number of their kits and have enjoyed building them. This model has always been on my wish list and when I was at a friends house recently, he wanted to swap it for a Trumpeter A7 with all the Zacto resin. Naturally I jumped at the chance!. Now, Aerotech make some pretty interesting subjects and their kits are either really simple or need a lot of work. This one luckily is on the easier side, with the parts fitting together well and it features nicely done detail. The aircraft itself is very esoteric, with it not ever having flown due to problems with its gearbox, nevertheless, it will fit in my collection nicely, having a couple of other subjects that reached the taxi stage but never took to the sky.
The Box, typical Aerotech it doesn’t really draw you into the subject!
apart from the nice resin parts, there is a fairly daunting looking sheet of photo etch which I guess will be the hardest part of the build.
Onto the build. I started with the instrument panel, which is a chunk of white metal overplayed with photo etch bezels.not much of this will be seen, so I didn’t spend too much time on it
next up was the cockpit. I replaced the kit photo the belts with simple tin foil belts that I made myself.
Barely any of this will be seen, so it has been kept very simple.
Re: 1/32 Aerotech Piaggio Pc7
Postby qfa_tsv » Thu Aug 30, 2018 5:08 pm
Wow that photo etch oughta keep you cool :D
Postby ericg » Thu Aug 30, 2018 9:02 pm
Thanks Graham, hope you get better soon mate,
I have spent some time replacing some of the resin pins with brass on parts that will be easy to break. The water rudder sticks out a considerable distance and knowing the properties of resin, it wouldn't take too much to break, so this was the first part to receive some attention.
The kit `pin'
I drilled a 1mm hole right through the rudder and fitted it with a brass pin. At least if it is knocked it will bend rather than snap off. I have set the brass with super glue and will tidy up the protrusion later.
I fitted a corresponding tube to accept the brass pin of the water rudder.
The ailerons have 1 pin to secure them to the wings. Once again, easy to snap off if the model is grabbed wrong.
I replaced the single pin with 3 x 1mm brass pins.
Similarly with the boat propeller.
This model has come together very quickly. Looks great from all angles. The kit comes with a multi part beaching trolley which I have partially assembled to rest the model on.
Postby ericg » Tue Sep 04, 2018 2:46 pm
Onto to the daunting task of getting the photo etch onto the wings. You only get one go at these and they will require some thought as to how they will attach to the wings. I considered a few different glues but settled on Zap 15 minute Zpoxy resin glue. You really need to be able to shift the panels around a little bit and it pays to work out exactly where they will go so that you don’t have to move them too much. At least with 15 minute glue there is some working time before the glue sets.i plan on priming the model with the panels in place and then repainting them in a suitable colour rather than leave them in their natural brass state.
Each panel was snipped off the carrier sheet, and this photo shows the way each panel has warped.
i used the top of the kit box and a large section of brass tube to roll each panel into shape. It is critical that the panel sits on the wing, following its natural curves and doesn’t have any areas that lift off the wing, or at least try to minimise that lifting.
mixed up and ready to go. I have already done the top panels and will align the bottom panels by eye to them. The glue allows the panels to be moved around to assist with this. I have roughened the mating surfaces.
Clamped with as many clamps as I could find in an attempt to further stretch the brass over the wing, especially the edges. Notice that the edge of the brass has been protected with Tamiya tape.
Reasonable success. Some areas will need a bit of a tidy up.
Postby DesTROYer » Tue Sep 04, 2018 4:06 pm
Excellent work mate.
Postby ericg » Thu Sep 06, 2018 2:56 pm
Thanks Troy
Onto some more etch! I always knew the nose radiator etch has going to give me grief, as it is thin strips of brass that only needs to be looked at the wrong way for it to distort. Despite carefully cutting it from the sheet, it didn’t want to play the game and that was before trying to fit it onto the model. Also the fact that any glue leaking from under each strip was going to be very hard to remove and fix whilst trying to keep it aligned for the glue to set. Any mistake would have meant damaging the part to remove it and start again. I certainly don’t like putting myself into that situation as a modeller so decided to come up with a better solution to alleviate my concern. Having worked with this type of surface radiator with the MC72 (the reason why it was shelved in the first place) leaves me wondering why Aerotech can’t incorporate this into the masters rather than giving the modeller a reasonably tough challenge to complete.
The area where the etch is supposed to go. Not the easiest of areas to be messing around with photo etch.
I used thin Evergreen strip to simulate what the photo etch would have done. To attach it to the model I used a new product to me, being Zap gel superglue which permits a reasonably long working time. I wasnt too concerned with aligning the strips length wise.
Tidied up. The strips are too high and stick out further than required but these will be sanded to match the profile.
I sanded the strips to about half their original height, and then primed the area to check my work.
Postby ericg » Fri Sep 07, 2018 11:35 pm
Another area of the kit that I tidied up was the rear of the spinner and the front of the fuselage. Due to the nature of the kit, both of these areas required some attention due to not being round, partly due to the imperfect join and some possible warping of the moulds. I ‘blueprinted’ these parts to ensure that they look good to the viewer of the completed model. I used my circle cutter to cut two disks of thin plastic card which closely matched each of the parts. Knowing that these were perfect circles, I was then able to backfill the resin part with a talc/superglue mix and sand to match the plastic disks.
Onto the painting stage. All good paint finishes start with surface preparation. I primed the model with Tamiya Fine surface primer. This stuff just seems to work.
i then use a strong light to closely examine the model and mark with a lead pencil every small flaw and imperfection on it. This then becomes my checklist of things to fix. For instance; a file mark, glue spot, a panel line that needs to be deeper etc.
A few hours spent here is time well spent. Lots of small fixes.
My objective for the days modelling was to get it into pink primer. I used Tamiya pink surface primer before on my DH-88 comet to give it a good base for the red and it worked very well. Not going to change anything there. Will let it sit for a day and give it a once over with some 2000 grit before shooting paint.
Postby qfa_tsv » Sat Sep 08, 2018 10:05 am
Wow with that spiffy blue interior, and now pink outside, I say just throw a coat of clear on it and be done with, just so cool, much better than red, a dio with it up on the skis running across lake Como.
good work with the etch, can't have been easy.
Postby noelbarnes » Sat Sep 08, 2018 10:49 am
What a stunning looking plane. Thanks for sharing all your know how. I love seeing how you problem solve some of the issues you come up against. Look forward to seeing the red go down.
noelbarnes
Postby ericg » Sat Sep 08, 2018 9:10 pm
Thanks Graham and Noel
I might paint it in rainbow colours so that no particular group feels offended.
So whilst looking for a particular paint colour for another project, I found that the same manufacturer made `Italian red', just the colour I was chasing for this project. There has been alot of talk here in Australia about a new manufacturer called SMS, or The Scale Modellers Supply so I thought I would give it a go. I normally would have used a Tamiya  spray can for this job as it has worked well in the past with the DH-88 Comet but felt it was time for a change. SMS is an Australian based manufacturer and the paint is made here, so I was keen to give it a go. I painted the model with my Iwata HP-BH set at 15 PSI straight from the bottle and achieved this result with two thin coats. I am extremely impressed with this paint and it has settled onto the model with a very smooth satin finish. I would highly recommend it.
